First Gaming PC Rig - Basic Questions and advice
Hey guys, I've been looking into making my own gaming dekstop so that I can finally run some games on high settings. I want to play games like Planetside 2 or Blacklight Retribution on max. I have a couple questions about the rig below:
Are all the parts compatible?
Is it SLI Crossfire ready?
Will it have enough power?
Are there any other parts I should get or change the ones I'm currently thinking about?
Should I add more cooling?
If I already have Windows 8 on a flash drive, can I easily install it onto the HDD.
Do you guys recommend putting the OS on an SSD.
And any other comments or advice will be of great help.
Here is the link to my rig:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=21115552
Thanks!
3 answers Last reply
More about first gaming basic questions advice
  1. get this motherboard instead asrock extreme4
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
    then get this gpu, a 7870
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
    Go with a 750w psu, yes that is enough for crossfire easily.
  2. If your spending that much, pop a ssd in there?
  3. Thanks for the help guys, I now think I have a pretty solid build.
Homebuilt Gaming Systems Product
