Radeon HD 6850 Crash/Freezing Problems
  • Radeon
  • Graphics
October 14, 2012 7:31:40 PM
Hello all, I recently built myself a rig and for the past month or two I have been having the occasional freeze. When it freezes I get a screen of static with no movement occasionally crossed with different colours (they change from time to time, but is almost always only one colour or two at max). I have checked the wiring and reseated the card so I do not think the problem lies there. Because of the static I assume it is because of my GPU, but I am not the epitome of knowledge so I could be wrong. Help would be appreciated:
Rig:
Radeon 6850
8g RAM
i5 2300k
AsRock Z75 Pro3
750W Coolermaster PSU
If you need any more info let me know and I'll see what I can dig up. I checked other threads of crashes for this card and I didn't find any that match what I have been getting. The crashes occur usually after extended use, sometimes 5+ hours on, others about 1-2hrs. I do not think it is a heat issue since I almost never hear my fans go to extreme speeds. Thanks in advance.
More about : radeon 6850 crash freezing problems
October 14, 2012 7:35:19 PM
Are you overclocking?
Have you tried uninstalling then reinstalling the drivers?
m
l
October 14, 2012 9:55:48 PM
Not overclocking, and I haven't done that yet. I'll give that a shot and see if it does anything. TY.
m
l
