My build is
i7 3770k
asrock z77 extreme3
radeon hd 7950
seasonic 750W 80gold
benq gw2250
One of the problem is, I cant find intel hd 4000 anywhere on my device manager.
After I finished building my computer, I had to connect my monitor using VGA cable (came with benq gw2250) and use a VGA to DVI converter and attached to my DVI on HD 7950. When I try to connect the monitor to the motherboard, I get no signal!
The other problem is, when I play games (I only tested sleeping dogs, hitman, and dota2) I get horizontal hazy lines with minor flickering. When I watch video or do anything else, it looks crisp and clear.
I searched online, could be a problem with GPU or monitor..
I was gonna try and use the built in intel hd 4000 on this monitor to see if the problem would go away... but like I said, I couldnt find the device. I even downloaded intel hd graphics divers and I got an error saying my computer is not compatible.
The monitor flickering could be a result of poor VGA to DVI converter. The converter is actually really old(~7 years old?), so I don't know if the old converter is causing the distortion while playing games.
What would you recommend?
Buy a new VGA-DVI converter, or RMA the monitor, gpu, or motherboard?
i7 3770k
asrock z77 extreme3
radeon hd 7950
benq gw2250
