I changed the fan and bought some cheap thermal paste. started working normally and would stay on without turning itself off, UNLESS i ran the two cpus at above 70 percent capacity.
replaced the cheap thermal paste with Honeywell Thermal Interface Material Processor Mounting Pad
PCM45F. Result. The PC would start up for about two minutes then crash , ie turn its self off.
Removed the above and replaced again with cheap thermal paste. computer now will not crash despite running the duel core at about 80 percent capacity.
I have been monitoring it with free speed fan software. it reads CPU temperature at about 50 to 60 C.
However GPU is at 100 C when turned on at rest. when the CPU works hard temperature rises to about 107 to 108 C of the gpu.
I suspect this GPU temperature is very high , would i be right in this assumption?
There is a separate area inside the laptop which is available a separate card. it is currently empty so i am assuming that it is using an embedded gpu on the board. would putting a separate gpu card into my ascer aspire be like putting in new memory. iE plug and play? would it be easy? would it solve my high temperature gpu problem?
any advice to a novice would be appreciated thanks.
