Specifically,
will this
http://www.amazon.com/PCI-Riser-adapter-Flex-Cable/dp/B0054C3BO6/ref=sr_1_12?ie=UTF8
adapter work on
http://downloadmirror.intel.com/15175/eng/D945GCZ_TechProdSpec.pdf
this motherboard ^ (1.0 x 16 pci slot, 2.8 GHz processor, 4 GB RAM)
for this card:
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-570
Because it for dang sure won't fit in my case.
Plan A. If you know 100% without a doubt that the answer is yes, just post a quick reply "yes".
I don't need the details. I know performance won't be slashed, all I want to know is that if I buy this adapter I will have the ability to install my card. That's all.
Plan B. If for some strange reason performance will actually be slashed by a lot, tell me to buy a 16x adapter if that will fix my problem.
Plan C. If that still won't fix my problem of maintaining performance and flexibility, recommend something else.
let's hope plan A prevails here
This is a very simple question that very few people ask.
will this
adapter work on
for this card:
