New build help
CPU: i5-3570k
MOBO: Asus P8Z77-V DELUXE
RAM: Corsair Vengeance DDR3 1600MHz 8GB 2x240 DIMM Unbuffered 9-9-9-24
HSF: COOLER MASTER Hyper 212 EVO
SSD: Samsung SSD840PRO 128 GB
HDD: Western Digital Caviar Black 1 TB
PSU: CORSAIR HX Series HX850 850W
GPU: GTX 670 Windforce 3x
DVD: Not decided
Case: Corsair 600T
Thermal Compound: Arctic Silver 5
I will play my games at 1080p.
Is there anything wrong with my configuration? In the future, I want to do 2-way or even 3-way sli gtx 670, can my system handle that?
Thanks.
8 answers Last reply
More about build help
  1. Your mobo can only go up to 2-way SLI. I would get this board http://www.newegg.com/Product/Product.aspx?Item=N82E16813128552 . I had it before. Amazing on board sound! Much better than Asus sound.
    Only need more than 1 670 if going at a higher resolution than 1080p or getting a 120hz monitor. 120hz monitors are amazing for 1st P Shooters. 5760x1080 is amazing for gaming as well. Though choice. Or you could get both like me.
  2. Gigabyte GA-Z77X-UD3H better motherboard
  3. Thanks for your replies. I think I will buy the G1 Sniper. The problem is that I am living in Japan and the products here are a little different from the US's. I wonder if this is the same one as in NewEgg:
    http://www.amazon.co.jp/GIGABYTE-intel-LGA1155-LucidLogix-G1-SNIPER/dp/B007MWZJKK/ref=sr_1_1?ie=UTF8&qid=1354803573&sr=8-1
    And one more thing: do you think Corsair 600T, a mid-tower, can handle 3 GTX 670s?? I want a PC that can do 3-way SLI because I want to play future hardcore games at max settings.
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128544 is better than the G1 Sniper. http://www.amazon.co.jp/s/ref=nb_sb_noss_1?__mk_ja_JP=%83J%83%5E%83J%83i&url=search-alias%3Daps&field-keywords=Gigabyte+Ga-Z77X-Ud3h
  5. If you haven't decided on an optical drive still, any cheap drive will be fine but I recommend http://www.newegg.ca/Product/Product.aspx?Item=N82E16827106289&nm_mc=AFC-C8junctionCA&cm_mmc=AFC-C8JunctionCA-_-CD/DVD+Burners+(RW+Drives)-_-Lite-On-_-27106289&AID=10592396&PID=3938566 it's by far the best for the price imo.
  6. Can you guys tell me what is the better part of these Mobo compared to Asus P8Z77-V DELUXE? I see many good reviews of Asus P8Z77-V DELUXE. I'm a newbie.
    I am just telling you what I prefer, the Asus P8Z77 is a decent motherboard too.
  8. After researching, I think I will get the GIGABYTE Z77X-UP5-TH, which is a little cheaper and has thunderbolt.
    http://www.amazon.co.jp/GIGABYTE-INTEL-LGA1155-Thunderbolt%E5%AF%BE%E5%BF%9C-GA-Z77X-UP5-TH/dp/B008JA2RSG/ref=sr_1_1?ie=UTF8&qid=1354976444&sr=8-1
New Build Corsair Systems Product
