Tom's Hardware > Forum > CPU & Components > Other Components > Help with floppy drive
Forum CPU & Components : Other Components - Help with floppy drive
Ok just installed my new mobo (abit kr7a-raid), cpu (1600+ xp), and HD but now my farking floppy drive won't read. It shows the floppy drive as working ok under the windows device manager but won't work whatsoever. I really need it to be fixed asap but is there anything that might be causing this? Thanks for the help.
Sponsored Links
How far did u overclock it? :) Seriously though, is it enabled in BIOS?
NOS and a <font color=red> Ferrari </font color=red> can be fun! :cool:
Reply to Flamethrower205
- 0 +
Double check and make sure you have floppy cable on new board with pin 1 in right place. I make that mistake once and won't forget that one.
<font color=blue>Remember. You get what you pay for. :smile: All advice here is free.</font color=blue> :wink:
Reply to OldBear
- 0 +
Yeah.
Possible reverse the cable, on my FD there isn't any mark for the pin 1 so it's just trying.
My case has so many fans that it hovers above the ground :eek: .
Reply to svol
Yeah it's enabled in the BIOS and no I haven't overclocked yet ;) I also checked the cable and having it in the right spot because I did the same thing with my HD earlier hehe... Also sorta hard to do since it has a clip on it.
Reply to Anonymous
- 0 +
Is your floppy light burning continuously after you started the system. If so the cable will be attached wrong although it has a clip.
Reply to svol
nope the light never turns on
Reply to Anonymous
- 0 +
Have you tried it with another cable?
Reply to svol
- 0 +
I'm not trying to be an a$$hole.
The floppy cable connector on the motherboard is keyed so its hard but not impossible to plug it in the wrong way.
The end that connects to the floppy drive has to be a terminated end. The end of the cable that plugs in here has a small bundled twist in it.
On the floppy drive the connector soldered to the circuit board will have a number 1 or 2 silk screened on one side of the connector. This designates the #1 pin on the cable. The #1 conductor on the floppy cable has a stripe on it.
When connecting the floppy cable to the floppy drive make sure the stripped side of the cable plugs into the connector on the drive so the stripe lines up with the #1 or #2 silk screened on the floppy drive circuit board.
(It sometimes has a #2 on it because the #2 pin on the connector is the first hole drilled on the circuit board.)
Again make sure the connector on the floppy cable plugging into the drive is the last connector on the cable and it has a small bundled twist in it. (You can still get floppy drive cables that have master and slave connectors on them.)
Last but not least don't forget to plug in the mini 12V power connector to the drive.
<font color=red><i>Happy Canuck</i>!</font color=red> ' :wink: '
Reply to zpyrd
Check the power cable. Make sure that if it's an extension of some kind that the extensions are plugged in right.
Also make sure the pins on the drive aren't bent.
Try swapping the power cable for another one (should have at least two with floppy connectors in there).
Don
If I can't see it in the viewfinder, it doesn't exist.
Reply to DurocShark
There are 1055 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
