Hello.. I'm building a gaming pc and my budget is 1000$ .
I've chosen all the other parts but still I can't decide what motherboard should I [ick.. here are the candidates
1-MSI Z77A-GD65 LGA 1155 Intel Z77 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130643&Tpk=MSI%20Z77A-GD65%20LGA
2-MSI Z77 MPOWER LGA 1155 Intel Z77 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130660&Tpk=MSI%20Z77%20MPOWER%20LGA%201155
3-ASUS P8Z77-V PRO LGA 1155 Intel Z77 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819
4-ASRock Z77 Extreme4 LGA 1155 Intel Z77 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
I want it to be good at overclocking and has decent futures Like Memory XMP.. If you have other boards on mind that you think will suit me better tell me about
here's the rest of my build:
-CPU - Intel i5 3570k ivy 3.4 turbo 3.8
-GPU - SAPPHIRE Vapor-X 100352VXSR Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16
-Ram - CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
-HDD - Western Digital WD Black WD1002FAEX 1TB 7200 RPM
-Case - Cooler Master HAF 912
-PSU - CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Also if you have other suggestions to my whole build please tell me thanks <3
I will be buying from newegg/Amazon.
I might crossfire in the future.
