Getting ready to embark on my first build in about 10 years, you could say my tech skills a bit rusty. Found this format to ask for help, I'd definitely like to get some input from everyone on here, you guys know a whole lot more than me on this:
Approximate Purchase Date: Over the next 2-3 months
Budget Range: up to $1300 (shipped)
System Usage from Most to Least Important: Gaming, interwebs, a little video editing, nothing fancy
Are you buying a monitor: Plan to hook up to a 46” 1080p tv
Parts to Upgrade: Full build
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Whoever has the best prices
Parts Preferences: Intel, Nvidia
Overclocking: Eventually
SLI or Crossfire: Eventually
Your Monitor Resolution: 1920x1080
Additional Comments: Plan to hook up to my TV in the living room and operate with wireless keyboard and mouse, quiet is preferable but not the priority. I’d like to build something that is expandable down the road (GPU, RAM) but that won’t need to be upgraded in a month to keep up with software.
And Most Importantly, Why Are You Upgrading: Want to build a machine that can run high end FPS (Far Cry 3, Battlefield) and memory sucking strategy games (Total War, Civilizations)…and make em look good.
Parts: This is just what I’ve dug up using my meager understanding of current computer fanciness, I’m totally open to suggestion. I picked a smaller HD cause I honestly don’t need any bigger. Don’t download much of anything for music or movies.
CPU: Intel Core i7-3820 BX80619I73820 Processor - Quad Core, 10MB L3 Cache, 1MB L2 Cache, 3.60GHz (3.90GHz Max Turbo), Socket R (LGA2011), 130W, No Fan, Retail--$289
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1884773&Sku=I69-3820
CPU Cooler: Noctua NH-D14 CPU Cooler - 140x140x25mm, i5, i7, 775, AM2--$84.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5592441&Sku=N126-1024
Motherboard: ASUS Sabertooth X79 TUF Motherboard - ATX, Socket R (LGA2011), Intel X79 Express, 1866MHz DDR3, SATA 6.0 Gb/s, RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCI-Express 3.0, CrossFireX/SLI--$329.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1498753&Sku=A455-3156
Memory: Corsair CMZ8GX3M1A1600C10 Vengeance Desktop Memory Module - 8GB, PC3-12800, DDR3-1600MHz, 240-pin DIMM, 1.5V, CL10, Intel XMP Ready, Unbuffered—$44.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1610526&Sku=C13-5708
HD: WD Blue WD5000AAKX 500GB Desktop Hard Drive - 3.5", SATA, 7200RPM, 16MB Cache--$59.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7281716&Sku=TSD-500AAKX
Video Card: MSI N550GTX-Ti Cyclone OC GeForce GTX 550 Ti Video Card - 1GB, GDDR5, PCI-Express 2.0 (x16), Mini HDMI, Dual DVI, DirectX 11, Dual-Slot, SLI Ready, Overclocked--$119.96
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7335355&Sku=M452-0550
Case: Cooler Master RC-430-KWN1 Elite 430 Mid Tower ATX Case - ATX/Micro-ATX, USB, Audio, 120mm Blue LED Fan, Black--$49.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6430030&Sku=C283-3122
Power Supply: Ultra LSP750 750-Watt Power Supply - ATX, SATA-Ready, SLI-Ready, 135mm Fan, Lifetime Warranty w/ Registration—74.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276567&Sku=ULT-LSP750
Optical Drive: Asus DRW-24B1ST 24X Internal DVD Burner - DVD±R 24X, DVD+RW 8X, DVD-RW 6X, DVD±R (DL) 12X, DVD-RAM 12X, CD-R 48X, CD-RW 32X, SATA, 2MB, Black, OEM--$16.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6078414&Sku=A455-5022
OS: Microsoft Windows 7 Home Premium GFC-02050 Operating System Software - 64bit, DVD—89.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5213932&Sku=M17-7302
WIFI: Gonna need it, got no clue what to look for.
Keyboard and Mouse: Logitech 920-002836 MK320 Wireless Keyboard and Mouse Combo - 2.4GHz, USB Receiver, Instant Access Hot Keys--$39.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6572352&Sku=L23-8134
Will purchase fans to fill available spots and keep this puppy breathing
Total (pre shipping): $1201.86
