I would like to build my next computer, but am very lost as to what I should do and what parts I should get as it’s my first time. With the help of a knowledgeable friend, I mustered up a build that seems pretty good, but would still like to know for sure if it would be good for what I’d like and in general, such as in terms of upgradability.
My main goal with this build would be to have a computer that can take a lot of abuse, but not necessarily have do anything too intensive. It’s common for me to leave my computer on over night and not uncommon for it to be left on multiple days at a time. This is with browsers, messengers, sometimes games, and other programs running. My current laptop lasted about 1 ¾ years before becoming very run down from this type of usage. The most intensive games I play are, and are like, Civilization V and Minecraft and I often have multiple browsers (with roughly 20-50 tabs open at any given moment), messengers, and other software open at once. I’d ideally like to spend between $700 and $1100 excluding OS and peripherals. Would this build be good for what I’m looking for? If not, what should I consider changing or adding? And would it be easy to upgrade in a few years to prevent having to buy a whole new computer or most of one?
Graphics: GIGABYTE GV-R795WF3-3GD
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz or Intel Core i5-3570k Ivy Bridge 3.4GHz
(I hear Ivy Bridge is better in general because it’s newer technology, but the 2500k is better for specific things. The prices barely have a $10-$20 difference, and I’m leaning toward the 3570k)
Motherboard:
I’ve seen several highly recommended motherboards, but all of them seemed discontinued. Is there a newer one that would be ideal for an i5 CPU?
Hard drive: Seagate Barracuda ST1000DM003 1TB
RAM: Corsair Vengeance 8GB
Power supply: Antec EarthWatts EA-650 650W 80 plus Bronze or SeaSonic G Series SSR-550RM 550W 80 plus Gold
(Which would be better? I assume they’re about the same. Or is there a better one for my build all together?)
DVD-Rom: SONY Black SATA Model DDU1681S-0B or Lite-On iHAS124-04
http://pcpartpicker.com/part/lite-on-optical-drive-ihas...
Case: APEX TX-381-C
(Any better case suggestions? I’d like a good one.)
OS: Windows 7
Thank you in advance for any help.
