Help GeForce gtx 660 ti installation
October 17, 2012 6:23:04 AM
Help
I need two 6 pin pcie power supplies to plug into card, but my old card only took one, and there are no other available 4 pin power cables to plug into( I need two of them) coming from my power supply, the power supply is 600watts, the minimum spec was 500 watts for the card, yet I do not know how I can hook it up to the power supply, model psaz-cp600
What do I do?
Was told this would be a plug n play experience, heheh, so can I daisy chain with some sort of adapter and hook both pcie cables to only two of the 4 pin cables, instead of the current 2 4 pin cable to one 6 pin pcie cable setup?
I kinda doubt it.... But hopeful I can get this to work somehow. I cannot find any other 4pin cables coming out of current power supply
So then new power supply?
Then what, I am 43, and haven't screwed round too much in years doing this kinda thing.
Thanks,
Lee
