Finally Finished my first build. Damn that was a lot of work.
Last response: in Systems
I just hooked up the Komodo GPU block and the extra 200mm radiator. My cooling system is
Reservoir > 1500 L/h Pump > 240mm Radiator > CPU > RAM> 200mm Radiator > 7970 > back to reservoir.
After upgrading the pump, 200mm rad, and adding the GPU my CPU tems have fallen alot. CPU used to idle around 50C now its 39C-42C. MY 7970 with stock cooler would also idle around 50C, now it idles around 29C. I also decided to get rid of that Ekoolant crap and go with distilled water with a kill coil.
Related ressources
Thanks for the compliments.The GPU cooler is the KOMODO-HD7900 series full cover VGA waterblock. My specs are
Intel i7 960 oc @ 4.1 GHz
12 GB Corsair Dominator GT RAM at 1700mhz
ASUS Rampage III Gene
Coolermaster Silent Pro Gold 800w PSU
Sandisk 240GB SSD
MSI R7970-2PMD3GD5 Radeon HD 7970
Alphacool VPP655 Pump 1,500 Liter/Hour
Right now I have my GPU at Power limit =20%, Core Clock= 1125 MHz, & Memory Clock= 1575 MHz. I'm going to try to get the core clock past 1300 but afterburner has been giving me problems trying to increase the voltage.
The case is a Corsair 600T and I must say the purchase I made that made me the happiest was the COOLER MASTER R4-S2S-124K-GP 120mm Case Fan 4 in 1 pack for $11.99. What a great deal on good fans.
