I3 2130 3300mhz 3mb+GeForce GTX 650 OR i5 3460 3200mgz 6mb+GeForce 9600GT (for G
zeul1337
30
Heya. I am faced with a dillema. Firstly, I have a bit of money to upgrade/change my pc. I have a very old system that was good in its time but now its done.
So far I ordered an SSD hdd 60 gb alongside my 500 gb one, 8 gb of ram ddr 3 and a Gigabyte B75-D3V, socket 1155 mainboard but I am faced with the next dillema:
I can only afford one of the following combos and they go as is:
and i3 processor Intel® CoreTM i3 2130 SandyBridge, 3400MHz, 3MB, socket 1155, Box PLUS a shiny new GeForce GTX 650 which seems an awesome card for its price.
OR
and i5 processor Intel® CoreTM i5-3470 3200MHz, IvyBridge, 6MB, socket 1155, Box BUT I would be forced to stick to my 5 year old card which is a GeForce 9600GT. Which according to the nvidia site is not bad at all but still... its ages old.
I basically wanna be able to play most games with smooth FPS. What should I pick?
Thanks a bunch in advance.
zeul1337
30
7750 as in the ati radeon video card? if so why just curious
zeul1337
30
I could afford this http://www.emag.ro/placa-video-sapphire-amd-radeon-hd-7770-vapor-x-1024mb-gddr5-128bit-dvi-hdmi-pci-e-11201-05-20g/pd/E1LFKBBBM/
or this http://www.emag.ro/placa-video-gigabyte-nvidia-geforce-gtx650-2gb-gddr5-dvi-pci-e-n650oc-2gi/pd/EBYNKBBBM/
Which one would be better if I got for the i3?
which i3 I figured to be this: http://www.emag.ro/procesor-intel-174-core-small-sup-tm-sup-small-i3-3220-3300mhz-3mb-socket-1155-box-inbx80637i33220/pd/EWZTKBBBM/
zeul1337
30
kinda equally there, the radeon is slightly cheaper but not enough to make the difference. meanwhile i noticed i could also squeeze in a Intel® CoreTM i3 2130 SandyBridge, 3400MHz, 3MB, socket 1155, Box if im sticking to i3.
Which card should I go for? A friend of mine whom I deeply respect kinda vouched for the nvidia cards for some reason.
zeul1337
30
Also it's a no brainer that I should deffinetly get one of the video cards instead of an i5 and sticking to the 9600 gt right? I mean I sorta feel it dragging the whole system down..
zeul1337
30
Oh I will. I just hope karma doesn't come back to bite me back =)) It usually does when i slightly spoil myself :p Thanks for all the help! Now if i can only persuade them to deliver today and not monday..
