I have a customer computer that uses the following motherboard:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=672&CategoryID=1&MenuID=16&LanID=0
It has been working for years just perfectly, I play on it every single day. I shut it down last night to go to work and I come home today and it wont turn on.
I opened the case to check it, and when I hit the power button, the cpu fan spins about 2 rotations and then all power is completely gone.
I mean it has been working just fine forever, nothing happened to it, and noone was messing with it. I just shut it down for the night and came back the next day and now this is the issue.
As mentioned when I hit the power button on the top of the case, the CPU spins about 2 - 3 rotations and then all power shuts off, there is nothing else after that.
Let me also add that i checked the connector between the power button and the motherboard it seems taht the power connector from the button to the mobo is a bit bent, but has always been that way.
Also i put on a new power supply to it and it is still doing the same thing.
