Help with building amazing computer
lemunz
4
Hey guys I'm planning on buying an amazing computer which wont need anything replaced in a long time. I dont want it 20 000 dollars over the top but still I want a perfect computer with ssd and everything and I just wanted your opinions on what this build would be (Preffered ati but nvidia is fine also).
Im not looking for a pre built computer or one from alienware or anything but a list of parts that would coexist perfectly. If anyone does choose to try this I would prefer if you were to use newegg
I go by the newegg reviews; prices can change, so be flexible. Download the motherboard manual first if this is your first build. Change to a different motherboard if you can't understand the basic instructions from the manual.
http://www.amazon.com/Dell-ST2321L-23-Inch-Screen-Monitor/dp/B007Y0EQE0/ref=sr_1_6?ie=UTF8&qid=1355060449&sr=8-6&keywords=dell+monitors good value and quality $140.
http://www.newegg.com/Product/Product.aspx?Item=N82E16832416550 windows 8 $100 (on sale for $80 at frys or newegg email promo recently; register with newegg)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208046 Case $50 after rebate, free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027 power supply $52 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202004 7850 sapphire video card $160 after rebate, free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295 Z77 board $145
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 Cpu $215
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147096 ram $35
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135252 blue ray burner $40 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126097 keyboard, mouse $21
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227726 120 gb ssd $109 ( I use an agility 3; no problems yet)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148321 hardrive retail boxed $80
total: about $1147 after rebates
maxalge
Champion
Ambassador
