Custom Built Desk - Need Advice on Wall Speakers
December 8, 2012 5:58:15 PM
I've had luck here before with tech issues but this is a little more out-of-the-box question. I need advice on what speakers would fit well with this custom-built setup I made. I live in a small condo with limited space so I built a space-saving desk in an unused corner with a "clean" look. Everything is done aside from getting cables for the dvd-rom which will fit into the slot in the desk. My monitors have built in speakers but they're insufficient for gaming or music listening.
What speakers do you think I could use to mount above the monitors? I haven't had much luck searching online. I want to keep the look "clean" with all wires running through the wall to the pc in my furnace closet. They'd need to be powered speakers of course and optimally would have a headphone jack in the speaker when I want to use my headset. Here are some photos to give a visual idea:
Any thoughts or just general brainstorming would be appreciated.
EDIT: Maybe a soundbar?
