Need advice on new build
Waywhite
7
Whats the rig for, the i7 (which is locked, so why the Z77 board and cooling?) says video editing, but the 8GB of RAM says gaming. Also the PSU is overkill if your just after a single GPU.
Knowing what the rig is for will help us know how to help you. There are also some things that can just be generally improved though.
Newer and cheaper HDD.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Cheaper board with roughly the same features (one less SATAIII port is the big one)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128546
Better HD7870 model.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127681
blane2
28
Looks fine to me. I didn't look so you should double check your case and make sure your gfx card will fit. It should be fine... but on some cases you have to remove a harddrive cage to fit really big cards.
Waywhite
7
Thanks for the advice...
Waywhite
7
Thanks for the advice. Making this a gaming rig and to have enough wiggle room for expansion. Not going to overclock.
You mentioned cooling. With this type processor, what is the normal temp in degrees shoudl I be concerned with? Anything over 60 constant? What are minimal levels?
If its a non-overclocking gaming rig, then get an i5-3570 and a H77 board. The i7 isnt needed for gaming and the $100 extra for it can be spent on a bigger graphics card, which is more important.
Also you can downgrade the PSU to a 650W if you arent going to Crossfire/SLI.
What temps you should be getting will depend on room temperature largely and whether the CPU is under any load or not. But as long as it stays under 80c at full load (Prime 95) there's no issue with it running too hot.
Waywhite
7
Good deal. Thanks alot.
Waywhite
7
Hmmmmmmmm
Good point. Need to look at adding Ssd drive in this build. Se the tb drive for other stuff
