Build:
Case: HAF 922
PSU: PcPowerandCooling 600w Silencer
MoBo: AsRock Extreme4 Z77
CPU: i5 3570k
This week, after months of careful planning and research I pulled the trigger and bought parts so that I could build a gaming pc. Today I finally got around to building it and it was going pretty good. I used the newegg tutorial and aside from a few confusing parts, I finished the external build without problems. I moved everything in the case and started wiring and managing cables. I was having trouble finding the psu cable to power the case fans, so I plugged in the only cable that looked like it would fit. I turned on the psu to see what powered on and then the cable that connected the fans to the psu started smoking. I immediately turned everything off and unplugged all cables. I was wondering what may of caused this issue. I am very frustrated that after all my careful planning, I still failed at the last minute. Do you think this is covered by the warranty? I'm really scared that I need to buy a new part. I'm going to try to go to my local MicroCenter tomorrow for some assistance, although I bought my CPU cooler and case from newegg. Will they still help?
Case: HAF 922
CPU: i5 3570k
