Help with choosing PC Case and PSU
Last response: in Systems
December 9, 2012 1:35:45 PM
Hi guys i am building my own rig. Here are my main specs:
Mobo: Asrock 990FX Extreme 3
CPU : AMD FX-8120 black edition
GPU: Sapphire HD 7770
The above are already ordered .
I'm thinking about this case : Zalman Z11 Plus Midi Tower Case
link: http://www.amazon.co.uk/Zalman-Z11-Plus-Installation-An...
i'm open to suggestions...
More about : choosing case psu
December 9, 2012 1:39:10 PM
Do you want a flashy case? a mid tower or a full tower
m
l
December 9, 2012 1:55:39 PM
I want something that will keep the stuff cool. The smaller the better - just to fit everything. The design is not important as the tower will be hidden.
m
l
December 9, 2012 3:18:57 PM
2 reviews of the best cases under 50$ (or around that)
I would recommend the Antec Three Hundred That seems to be the best case for a budget and I heard its pretty decent to build in the only thing that you might want to get is some extra (cheep) case fans to keep it cool.
Good luck!
http://www.tomshardware.com/review [...] ,2707.html
http://www.tomshardware.com/review [...] ,2723.html
m
l
December 9, 2012 4:03:20 PM
The links above are not working. Could you fix them ?
m
l
a b B Homebuilt system
December 9, 2012 4:30:30 PM
Good luck!
i really cannot recommend the Antec 300. its a slightly outdated case with no cable management options(which why v2 exists, even still its a bit pricey for what you are getting)
doing a very quick run through of cases, teh case you picked is a usable choice, others on amazon.uk would include some of Aerocool's models as well as the bitfenix shinobi.
m
l
December 9, 2012 4:34:59 PM
I heard great things about the HAF 912 and NZXT M59/Gamma if you are going for a budget oriented case.
m
l
