How can i setup dual monitor display in imac running window7?
Hello,
how can i set up dual monitor display on my imac running window 7 with parallels? I have no problem when I run mac but when I run window, dual display doesn't work.
I heard AND radeon has some problem with window 7 display setting. does anybody know?
1 answer Last reply
More about setup dual monitor display imac running window7
  1. First you need to answer some basic questions: Do you have the latest drivers installed, and does Windows actually see both of your displays?
    If the answer to both of these questions is yes, then do the following:
    Right click on the desktop->Screen Resolution.
    In this window you can choose how you want the displays set up; ie, cloned, side by side, etc. If they're side by side but they aren't in the right order, you can click on the little animated display and drag it to where it should be relative to your main display.
    Hope this is somewhat helpful!
Configuration Dual Monitors iMac Windows 7 Displays
