T tushardehra Distinguished Jul 29, 2012 692 0 18,990 Oct 21, 2012 #1 i have a [a;it gt 430 gpu and at the bottom physx is not marked i mean its disabled why?
paddys09 Distinguished Sep 1, 2011 858 0 19,010 Oct 21, 2012 #2 Are you trying to run this as a dedicated PhysX card? Upvote 0 Downvote
T tushardehra Distinguished Jul 29, 2012 692 0 18,990 Oct 21, 2012 #3 i dont get u wat u mean? Upvote 0 Downvote
paddys09 Distinguished Sep 1, 2011 858 0 19,010 Oct 21, 2012 #4 If it is your main graphics card it wont handle PhysX very well anyway, but if you go to the Nvidia control panel and select your card under "set physx configuration" does it appear in GPU Z? Upvote 0 Downvote
T tushardehra Distinguished Jul 29, 2012 692 0 18,990 Oct 21, 2012 #5 no its not already done that but at 12pm today it was marked now i dont know y Upvote 0 Downvote
paddys09 Distinguished Sep 1, 2011 858 0 19,010 Oct 21, 2012 #6 Not sure tbh, but if its not marked in gpu z, it usually means that it is not selected to run in the Nvidia control panel... Maybe another piece of software is conflicting with it? Upvote 0 Downvote
