Hi- This is my first time building a system, so I was hoping I could get some advice from you guys. First of all, does this build seem reasonable, and if you notice any problems, could you let me know? Also, there is a second one, and I was hoping for some opinions as to which one to do.
Motherboard: Asus Socket AM3+/ AMD 970/ Quad CrossFireX/ SATA3&USB3.0/ A&GbE/ ATX Motherboard (M5A97)
CPU-AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
Video Card: SAPPHIRE 100355-1GOCL Radeon HD 7850 1GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card OC Version or EVGA 01G-P4-3650-KR GeForce GTX 650 Ti 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card- I'm not sure which one, I know the first one is better, but will the second one be adequate?
Hard Drive: 500GB 7200.12 Barracuda Hard Disk Drive 3.5-Inch | SATA 6.0Gb/s | 7200RPM | 16MB Cache
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
Case: CoolerMaster Elite 371
Power Supply: Thermaltake TR-600 TR2 ATX Power Supply - 600W, 120mm Fan, Cable Managment Optimized
Optical Drive: Lite-On Super AllWrite 24X SATA DVD+/-RW Dual Layer Drive - Bulk - IHAS124-04 Version C (Black)
That is the first one-
Second
MSI Z77 Motherboard, Intel core i5-3470 Processor, 2x Corsair XMS3 4GB DDR3 rams, EVGA GTX650 1GB, Toshiba 1TB HDD, Samsung 24x DVDRW, Thermaltake 600W PSU, and Cooler Master Mid-tower ATX Case.
The second one comes as a bundle, not sure if that matters.
Anyway, I'm hoping to use this system for some gaming such as Total War games, including Rome 2 total war when it comes out, Planetside 2, and Guild Wars 2. Those are some examples, hopefully others as well. They are both about the same price. Let me know what you think, and if one or both of the builds is more power than I need. Thanks alot!
EDIT: I am on a budget, so that is why some are cheaper parts. If there are equal quality parts that are cheaper which you know of off the top of your head, feel free to let me know.
Second
