Total NOOB Needs Help Cutting Build Plan to $650-750
Last response: in Systems
Hello,
I have been researching this and other sites to see what the experts say about critical/non-critical components for a new gaming build. I have a monitor I want to reuse. It has built in speakers. I also have Windows 7 and MS Office software I can reload on new system.
I myself am not a big gamer and my system will mostly be used by me for office related activity. *However* I have three boys that have fried my current desktop playing GW2, LoL, Starcraft and similar. They aren't constant users, but time has taken a toll.
Based on the above use, I came up with this build and have a friend who can help do it. My question: It's a little out of budget and I wondered if anyone can suggest "downgrades" that will keep the system relevant for 3-4 years anyway (and my boys will be out of college by then and can hopefully afford their own!) haha.
Obviously, no overclocking and all those other terms you bandy about that since I don't know anything about them, means I will probably never use/need them! 8-)
Here it is:
Intel Core i5-3570 3.4 GHZ $169.99 (MicroCenter)
Coller Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler $24.99 (Amazon)
Gigbyte GA-H77 DS3H ATX LGA155 $95.23 (NCIX US)
Corsair Vengeance 4GB (2x2GB) DDR3-1600 $27.98 (Amazon)
Seagate Barracude 1TB 3.5" 7200 RPM $67.99 (NCIX US)
MSI GEForce GTX 660 Ti 2GB $290.99 (SuperBiiz)
Creative Labs Audigy SE 24-bit 96 KHz Soundcard $25.99 (SuperBiiz)
Corsair 200R ATX Mid Tower $59.99 (Newegg)
Corsair Enthusiast 650W 80 Plus Cert. ATX12V $95.98
Lite-On IHAS324-98 DVD/CD $19.99 (SuperBiiz)
Final Price: $873.13
Last questions: Should I go up to Windows 8? With built in speakers in monitor, I assumed I still needed some kind of soundcard, but wasn't sure - feedback? Did I miss anything that needs to be installed? All prices include shipping and none of the rebates, as those come as cards, not discounts.
Your feedback is appreciated!
Linda
Here it is:
Linda
More about : total noob cutting build plan 650 750
I´d not worry about W8 as you have W7.
You really don´t need a 650W PSU, so save some by getting a CORSAIR Builder Series CX500 500W http://www.newegg.com/Product/Product.aspx?Item=N82E168...
You can discard the sound card completely, your motherboard has adequate sound capabilities. You can also change the power supply to a COOLMAX ZX Series ZX-700 700W ATX12V v2.2 (also 80 plus certified with 50 extra rated watts) for $49.99 at NewEgg.
That brings you down to $801 and change. Any other reductions would require performance compromises.
I'd not be saving on RAM especially when it's so cheap. Get 8GB (it's less than $20 extra over 4GB kit you picked), else you'll have alot of HDD swapping going on which gets rather annoying. I just fired up SC2 to check and my RAM usage jumped to 3,9/8GB.
Also, if you wanna save money, drop the sound card seeing as you have flimsy built in speakers. The one on the motherboard will be more than enough.
ASRock Z77 Pro3 => cheaper motherboard and allows overclocking unlike H77 one you listed. ignore this, I missed CPU being non-k and the part where you said you won't be overclocking
ASRock H77 Pro4/MVP $79,99
Related ressources
- Need help building a comp - Total Noob - Forum
- Gaming Build , $ 650-$750 - Forum
- Total OC noob w/ i5-2500k questions - Forum
- New Gaming PC Build : First Time Noob Needs Help - Forum
- Total NOOB first build help with gaming comp - Forum
takeitfor4 said:
...I have three boys that have fried my current desktop playing GW2, LoL, Starcraft and similar...
Here it is:
Linda
I play a lot of GW2 myself. You can cut this down considerably, and still have a great experience.
CPU: GW2 does like a strong CPU, so the one you chose (non-K) or an i5-3470 will do well.
Cooler: Technically not needed since you won't be overclocking. If you'd like one because it will be a little quieter, get this Xigmatek Gaia for only $20: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The mobo and RAM you've selected are fine; not worth muddying the water by niggling. The hard drive is "ok." Personally, I buy only WD Black drives now, because while most others have cut back, these drives have retained a five year warranty.
Where you'll get to save a lot of money is the graphics card. Guild Wars 2 (and other games) will run nicely with "Good" settings on a $130 HD7770. If you want something a little nicer, a HD7850 for around $170-$190 is still $100 cheaper.
You won't need a 650W PSU for this build either; for $80 I'd get this 520W Seasonic: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
You also will not need a sound card; your monitor's speakers (or other speakers) will connect to the audio out jack on the motherboard. Monitor speakers really don't sound all that good. Even a $40-$50 set of 2.1 speakers (two satellites and a subwoofer) will sound a LOT better.
Finally, one optical drive is much like another, so your choice is fine. The case is also a personal-choice item; find one you like, since you have to look at it.
Edit: Removed the "K" from the CPU; the i5-3470 is not a "K" model.
The Corsair V2 Builder is NOT a great PSU. It was made by CWT, not Seasonic, using inferior Samxon capacitors from a line known to experience early failure.
The Chokemax PSU is also a bad choice; I believe that one failed in Jonnyguru testing a while ago. Stick to Seasonic, Antec, FSP, or Enermax/LEPA.
Onus said:
The Corsair V2 Builder is NOT a great PSU. It was made by CWT, not Seasonic, using inferior Samxon capacitors from a line known to experience early failure.The Chokemax PSU is also a bad choice; I believe that one failed in Jonnyguru testing a while ago. Stick to Seasonic, Antec, FSP, or Enermax/LEPA.
Which of these PSU's would you recommend most? Which will be best bang for the buck? Specific models would be appreciated. Thanks!
Onus said:
I play a lot of GW2 myself. You can cut this down considerably, and still have a great experience.CPU: GW2 does like a strong CPU, so the one you chose (non-K) or an i5-3470K will do well.
Can you specify which model of the HD7850? As I mentioned, I am verrrry ignorant and took quite some time to come up with the list I made, so I'd like to save time and have pointers to what others are specifically recommending. Thanks so much!
takeitfor4 said:
Which of these PSU's would you recommend most? Which will be best bang for the buck? Specific models would be appreciated. Thanks!I linked the 520W Seasonic in my first post. That's a good one. There are others. If you're a big fan of efficiency, here is another good choice: http://www.newegg.com/Product/Product.aspx?Item=N82E168... also $80. It is "only" 450W, but that's all you need, even if you get the HD7850. If you choose the HD7770, this 360W model will be enough: http://www.newegg.com/Product/Product.aspx?Item=N82E168... for $60. I have used two of those recently, for my wife and one other. Neither has a strong graphics card in it, but it will have no trouble with a HD7770.
Onus said:
I linked the 520W Seasonic in my first post. That's a good one. There are others. If you're a big fan of efficiency, here is another good choice: http://www.newegg.com/Product/Product.aspx?Item=N82E168... also $80. It is "only" 450W, but that's all you need, even if you get the HD7850. If you choose the HD7770, this 360W model will be enough: http://www.newegg.com/Product/Product.aspx?Item=N82E168... for $60. I have used two of those recently, for my wife and one other. Neither has a strong graphics card in it, but it will have no trouble with a HD7770.Didn't catch that! My bad! Thanks for the info. Much appreciated!
I'd probably choose this one: http://www.newegg.com/Product/Product.aspx?Item=N82E168... even though it isn't the cheapest one. I've had good results from XFX, and I like the idea of two fans on the cooler because they can actually be quieter than just one (because they run slower), but if one fails, the card can still cool itself. Like many of the HD7850s, it comes with a couple of free games too.
This one from Gigabyte is a little cheaper. I don't think I've ever owned a Gigabyte graphics card, so I cannot vouch for their quality. Their mobos are pretty good though. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Well, you've all been great to help me out here! I feel pretty good about the following configuration, so barring any last minute commentary, I think I'll pull the trigger on this:
ASRock Z75 Pro3 ATX LGA1155 $92.55 (Newegg)
XFX Radeon HD 7850 1 GB $197.55 (Newegg)
SeaSonic 520W 80 Plus Bronze Cert. ATX12V $79.99 (Newegg)
Final Price: $741.02 with shipping!
Nice hit on the target pricing
For exactly the same price get a CPU with ´K´, which means it can be overclocked. I know you´re not into it, BUT at some point in the future, you will be able to increase the speed, thus performance!
http://www.microcenter.com/product/388577/Core_i5_3570K...
SAPPHIRE is cheaper ($174.99 after $15.00 rebate) it also has a better cooler system, and it is much better than XFX.
SAPPHIRE 100355-1GOCL Radeon HD 7850 1GB http://www.newegg.com/Product/Product.aspx?Item=N82E168...
For just 5$ more get Hyper 212 EVO http://www.microcenter.com/product/373900/Hyper_212_EVO...
The system you´re building deserves a bit more RAM, so get Vengeance Series 8GB DDR3-1600 http://www.microcenter.com/product/354611/Vengeance_Ser...
http://www.microcenter.com/product/388577/Core_i5_3570K...SAPPHIRE is cheaper ($174.99 after $15.00 rebate) it also has a better cooler system, and it is much better than XFX.
No. Overclocking is not a requirement. That CPU is already powerful enough that overclocking will not be necessary for this PC's intended purposes, now or in the foreseeable future.
Not so on the Sapphire. Its cooler is comparable, but there is no basis to assert it is better. In fact, Sapphire uses some iron core chokes, which are less efficient than the ferrite chokes that XFX uses.
No CPU cooler is needed, and I can never recommend anything from Crappermaster, since that company is provably dishonest. If one is wanted anyway, the Xigmatek Gaia I linked is cheaper, quieter, and cools within 1C.
Who said that overclocking is a requirement? Please do not place words in my mouth.
How can you say that 3.4 GHZ will be enough for the future? I listed a ´K´ CPU with the same price, there is no point in not getting it!
SAPPHIRE is much better than XFX!
I don´t really care about your personal problems with Cooler Masters -- Hyper 212 EVO is the best cooler out there in its price range.
People are still playing current games on old Athlon II X2s, which were never high-end CPUs; I cannot think of why a currently top-tier modern CPU won't be easily enough in a similar period of time. If it's the same price, it certainly isn't going to hurt, but if saving money is a goal here, one of the lesser i5's will do just as well. I played GW2 recently on an E6750 with a HD6670. No, it was obviously not as good as on the weaker of my two systems, but it was playable. It simply isn't necessary to pay top dollar just to enjoy games.
You may be thinking of the Vapor-X models, which supposedly have the best coolers. Sapphire's other cards are no better (nor necessarily worse) than any others. I've never had a XFX card fail, nor a Sapphire. The three XFX cards I have now are very well made, with aluminum rather than plastic shrouds, and ferrite chokes. They are very quiet. I'm not going to say that Sapphire isn't as good, but I do not accept that they are better.
The Gaia is $20, vs. $35 for the Crappermaster; that's a significant difference. Many people don't care if they support a dishonest company; I'm sufficiently "old school" to believe that dishonesty should have consequences. If you can look around you at the consumer fraud, shoddy goods, crony capitalism, corruption, etc. etc. all around us and not agree, then I suspect that one of us may have a less than average IQ.
Onus said:
No CPU cooler is neededOnus said:
The Gaia is $20, vs. $35 for the Crappermaster; that's a significant difference. Many people don't care if they support a dishonest company; I'm sufficiently "old school" to believe that dishonesty should have consequences. If you can look around you at the consumer fraud, shoddy goods, crony capitalism, corruption, etc. etc. all around us and not agree, then I suspect that one of us may have a less than average IQ.First of all, if "no CPU cooler is needed" as you said, why have you recommended an after market cooler then?
Secondly, I do not support dishonest companies, nor ´consumer fraud, shoddy goods, crony capitalism, corruption, etc´. I was just talking about a product -- Cooler Master make crap PSUs, but they make excellent cases (HAF 912, 922, 932, etc) and efficient after market coolers.
Finally, there is a difference in price, however at its price range, as I have already said, EVO, whch is made by Cooler Master, is a better product than Gaia -- quality has its price http://www.maximumpc.com/article/%5Bprimary-term%5D/xig...
I'm not debating the quality of Crappermaster's cases or coolers; as a dishonest company I will always recommend against them. Fortunately they have competition in every market segment where they are found, offering comparable (or better) products. Frostytech found the Gaia was 6db quieter and cooled within 1C of the Hyper 212 EVO. It's cheaper; $15 is a small absolute, but over 42% in relative terms, and is a big bang/buck win.
I said an aftermarket cooler isn't needed, but if one is wanted anyway (perhaps to lower noise), the Gaia is a good choice, especially since it is the quieter of the two of them. Fortunately, it has become a moot point, as the OP is not getting an aftermarket cooler.
Incidentally, when I install a pushpin-type cooler like the stock one, I often do it on a deck of cards or a roll of tape to avoid flexing the mobo too much; OP your friend may already have a preferred method, that's just what I do.
Onus said:
I'm not debating the quality of Crappermaster's cases or coolers; as a dishonest company I will always recommend against them. Fortunately they have competition in every market segment where they are found, offering comparable (or better) products. Frostytech found the Gaia was 6db quieter and cooled within 1C of the Hyper 212 EVO. It's cheaper; $15 is a small absolute, but over 42% in relative terms, and is a big bang/buck win.I said an aftermarket cooler isn't needed, but if one is wanted anyway (perhaps to lower noise), the Gaia is a good choice, especially since it is the quieter of the two of them. Fortunately, it has become a moot point, as the OP is not getting an aftermarket cooler.
Calm down guy, coolermaster makes some sweet products
Stop being so one sided because they hurt your feelings
@OP No do not get windows 8 unless you have a touch monitor or some crap
Windows 7 is much better and I feel windows 8 is just as skipable as windows vista was
ybnrmalatall said:
Calm down guy, coolermaster makes some sweet products...You miss the point entirely. Yes, they offer some excellent products, but the company is dishonest; buying any of those products supports dishonesty. It has nothing to do with my "feelings." Failure to impose consequences for willful wrongdoing is the #1 reason our society is headed down the crapper. Maybe this example is trivial, but a line needs to be drawn.
Cite errors in fact, or be quiet. The site is remarkably non-commercial, without the extra dozen advertising / tracking sites to block that BestofMedia uses. Iirc, they also escaped payola accusations of some years ago. Their tutorials are also solid. I am not familiar with the Brazilian site, but I don't find other reputable review sites disagreeing with Gabriel Torres' findings in his reviews.
So it is Cooler Master vs Gabriel Torres!
Anyway, HardwareSecrets also made a review on the Cooler Master Hyper 212 EVO CPU Cooler -- it got the Hardware Secrets Golden Award. http://www.hardwaresecrets.com/article/Cooler-Master-Hy...
How about their own product literature? Claiming a circuit is present when it is not isn't being overly optimistic, it's an outright lie.
Anandtech found their sickleflows to be grossly overstated as well, although I can accept that as in the realm of marketing "exaggeration." HardOCP is another source concerning their PSUs. Anyway, I don't want any of us to get banned for hijacking this thread. Enough is enough. I don't support dishonest companies. If you do, that's your choice.
Related ressources:
- ForumNoob powersupply question
- Forum$ 650-750 gaming PC – Advice Requested
- Forum$ 650-750 Does Everything Computer!
- ForumTotal noob to Phenom II x3 720 OCing, what do i have to do?
- ForumNee help , I am a total noob who wants to build a gaming PC
- ForumFirst Time noob $2,000-$2500 build
- ForumNoob needs help with new AMD gaming/multimedia build
- ForumTotal NOOB Needs help on 1st build
- ForumTotal Noob needs help looking over these components for first build
- ForumPlease check my first build ! Between $ 650-$750
- ForumXfx 680 half price
- Forum$800 Budget Gaming Build
- ForumMy build for Christmas
- Forum[Solved] Help with 700 to 900 Dollar Gaming Build
- Forum[Solved] Cheapest possiable build that can run BF3 on ultra
- More resources
