Closed Solved
Poe device hanging problem
Hello,
we have several windows device.
When we connect them with standard cable it work perfectly.
But when we connect them with PoE cable, we found problems like :
1. Device freezing automatically.
2. Can not reconnect to server
thanks for your any help.....
Regards,
Hardik
Software Engineer.
4 answers Last reply Best Answer
More about device hanging problem
  1. Best answer
    Depending on the power levels, you should be using cat5e or cat6 cables.
  2. How are your two cables different?
    Your standard cable is what? Cat5, Cat3, etc...
    PoE works just fine over Cat5, 5e, or 6 cable.
  3. Best answer selected by mousemonkey.
  4. This topic has been closed by Mousemonkey
Connection Devices Cable Networking
