Catalyst control center help
when ever i open ccc its all white and has the game ad they usually have, i would uninstall it and reinstall but windows 8 wont start in safe mode. i have Radeon HD 6770 with all the latest drivers install(tryed installing them like 20 times hoping it would do something). and the only reason im doing all this is because i want to get back on tf2, and when ever i play i get this message "failed to lock index buffer in CMeshDX8::LockindexBuffer" and im pretty sure it has to do with the gpu, but i cant even open ccc.
1 answer Last reply
More about catalyst control center help
  1. Sign in as administrator (If you are not administrator you may be blocked)
    Close all the applications that are being used...save and close your files...
    Turn Off the antivirus and firewall, turn off the functions of windows defender.
    If you have multiple security programs installed, they must be turned ALL off. Security will prevent your driver from installing...
    Download the latest CCC driver package, and save it to an easy location. Make sure this is the correct driver for your card.
    Delete all the current AMD video software and drivers, restart the system (the video will look screwy, don't worry)
    Now load install all the newest CCC drivers and restart the system (the driver will not work (yet) as you said, but load it anyway)
    left click start
    left click computer
    right click C drive
    Left click Open
    Right click Users
    Left click properties
    "Check" mark the box that says: Attributes: "Hidden" (there is now a check-mark in the "Hidden" box)
    Click: "Apply"
    Now the system will apply the hidden attributes...and this will take a while, or maybe a long while. Let this proceed, and don't interrupt it...
    During this procedure, a message may inform you that you do not have administrator privilege to the file you are trying to change the attributes of. That's OK. Just click: "ignore all."
    When this procedure is finished, click OK (the box will close after you click OK)
    Now you will once again be looking at folders in C drive (don’t close the C drive window or you may regret it)
    (once again) right click Users
    (once again) left click properties
    UN- check the box that says: Attributes "Hidden" (you will now take the check mark OUT, Hidden is no longer checked)
    Click Apply
    Now the computer will UN-apply the hidden attributes, and it may take a while, or a long while...but let it proceed, and finish, don't interrupt it.
    During this procedure, a message may inform you that you are not the administrator of the file that you are trying to change the attributes of. That's OK, just click: "ignore all."
    When this is completed click OK
    Now close all windows and restart the computer
    turn all the security back on.
    At this point, the CCC should be functional. Open the CCC and test the functions...
Radeon Catalyst Graphics
