Solved
Power Supply Upgrade!!
do i need psu upgrade for the following system:
core i3-540 (3.68ghz)
gigabyte h55m-s2
samsung 1TB
corsair 8GB 1600mhz (2x4gb)
LG dvd-rw
3x usb devices
sapphire hd 7750
and one more thing will cm hyper tx 3 fit with my ram sticks (corsair vengeance).
Note: my current psu is 450 watts and 17A@12V.
9 answers Last reply Best Answer
More about power supply upgrade
  1. I see some testing with the vid card was dun with PSU's under 450 with 0 problems so i would have to say yes. Whats the brand for your current PSU?
  2. That system should run fine with a 450W PSU. The 7750 does not require a power connector so no need for that. What brands is it, as asked above. If it's an el-cheapo everyone is going to tell you to replace it.
    The hyber TX-3 should be fine. The cooler itself is not wider than the socket, just the fan hands over so it shouldn't stick out far enough to be concerned about tall RAM. if it was a wider cooler you may have to reconsider.
    thanks mate, you wanna say Hyper TX3 will fit with tall ram on my mobo!!
  4. CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing
    Motherboard: Gigabyte GA-H55M-S2 Micro ATX LGA1156
    Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600
    I see no fitting problem
    Right, it shouldn't hang over the RAM modules.
    thanks but are you sure, will fit with Tall ram sticks. actually still confused...
    take a look again...
    RAM:
    COOLER:
    MOBO:
  7. should run fine on 450w if good power supply make :)
  8. Best answer
    0 fitting problem
  9. Best answer selected by Simu.
Homebuilt Power Supplies Corsair Systems
