Solved
New build works out of the box but in the case no post, all fan spinning
I am frustrated, my new build works out of the box, memory, cpu , mouse and keyboard all recognized by the bios.
When I install them into the case it turns on but no post, no beep, no power to keyboard and mouse.
Please help me, it must be a short into the case but all the standoffs are properly set..
13 answers Last reply Best Answer
More about build works case post spinning
    By the way, I have took it out of the case and everything is working perfectly, Ram, Dvd player and so.
    I have installed win 7 pro and the system is rocking.
    Any chance i will put it in my Rosewill Challenger gaming case one day?
  2. Best thing, take everything apart and try again.
    Also, try it with NO case fans connected. (keep the cpu fan connected ofcourse)
    NEVER ASSEMBLE ON CARPET.
  3. You did install ALL of the mobo risers that you need, and ONLY the mobo risers that you need into the case, right?
  4. Also, sometimes there are little plastic washers that you need to use to make sure there are no shorts, make sure that you used them where the mobo touches the mounting screws.
  5. Best answer
    I had a similar problem, i transferred the guts of my main PC into a better case, When i turned it on it would power on for a few seconds then shut off then on then off then on then off, until i pulled the power. So what i did was breadbox the system, it worked, then i put it back in the case, same problem. So i just laid the mobo on the standoffs, no screws, and powered it on, it worked, so i started screwing the screws in one by one and checking to see if it boot after every single screw. The problem turned out to be my wireless card was pushing down too hard on the PCIex1 slot that it was in. So i moved it to a different slot and presto, it worked. I suggest you follow a similar, if not the exact, method i just described.
    Thank you but I have already tried with almost nothing connected and out of the box it is working with "everything connected, including 3 case fans, I tried just in case"
    Yes I did, just the right amount of those
    The case didn't carry any plastic washer.
    +1 for this.
    Thank you, I guess I will try that.
    I also noticed that the holes on the mobo are no alligned with the standoff holes by the millimeter, just a thought.
  11. Best answer selected by fernandino.
    Great catch buddy, indeed it was one of the seven screws making the system freeze.
    I just skip it and with all the other screw (6 out 7) everything is working.
    Not enough for RMA since Christmas is too close and my son wants his Computer by then.
    I will find the way to put insulator rinds later on.
    Thank you all for helping me and fix it the same day.
  13. Good to hear, and thanks for BA.
New Build Cases New Build Keyboards Systems
