Hello,
I have a HP xw4600 workstation to which I want to add a Gigabyte GTX650 to replace my failing 9800GT.
The problem is that all I get from the machine (at boot) is 6 beeps indicating "Pre-video graphic card error."...
I have taken the following steps:
1. Tested the graphics card in another machine - a Mesh - works fine.
2. Removed and swapped memory to check if any of the memory is faulty.
3. Used the PSU from the Mesh machine in the HP - still doesn't work.
4. Removed all unnecesary peripherals (extra HDD, DVD, USB's, 2 PCI cards)
5. Ensured at each stage the old 9800GT still functions in the HP without issue.
Any suggestions? Clearly the graphics card works. I havn't had any problems with the HP and if the motherboard was faulty I would have expected an issue with the 9800GT.
edit: further to this I have tested the card in a similar machine where it worked - it wasn't the exactly same setup though. Not sure what else I could check?
