Solved
Sound card questions
this sound card: Creative Sound Blaster Recon3D THX PCIE Fatal1ty Pro Sound Card SB1356 i need to know if this sound card will work/fit in a cooler master haf 922?
4 answers Last reply Best Answer
More about sound card questions
  1. Best answer
    Anything that has PCI spaces supports PCI hardware. If your case didn't, you would be unable to even support a graphics card. So yes, it does.
  2. ok thanks
    and will it work with an intel z77 extreme6?
  3. Yes
  4. Best answer selected by YouJustGotCrafted.
New Build Sound Blaster Sound Cards Creative Systems
