ASUS RT-N16 Big Issue Help!
Hi Guys I need help I am getting a slow connection on the router ever since I got it. I get speeds of 5 to 3Mbps when I should be geting 19-20Mbps. I have searched everywhere but still no answer I am running the build 16994. I have done a hard reset, reboot the router and disabled the firewall, even change builds but still the same issue. I know is not the router cause it's Brand New. Any help would be greatly apprecited.
Thanks!
1 answer Last reply
More about asus issue help
  1. I had this exact same issue with mine... i assume you are using wireless and cable internet. I went into the wireless settings and then into professional settings and I disabled tx bursting, put greenfield into mixed mode and disabled wmm without acknowledgement. when it rebooted it instantly had the full 20 Mb connection.
Routers Asus Connection Networking
