Ok I’m new to oc and I want to buy a new computer system.
The pc will be for gaming only and I don’t want to change anything for 3 years (getting good to max performance in the game in 3 years’ time)
I want to play game in 1080p and in 3D. Not sure about 3D surround yet might do it in Q3 or Q4 of next year.If want 3d surround what spec should I need??
Current rig:
CPU> T10552.8ghz (oc3.6 ghz)
MOBO> MSI 890X-G65
GPU> MSI cyclone GTX 460 oc
8 gb DDR3 1333mhz (oc 1444)
So my budget is $2500(including Monitor) but also concern about the product worth it or not.
Salvage old pc Part: PSU > Cooler Master Silent Pro Gold 1000W
HHD> WD 1TB Green
Planning Build:
Chasing > Cooler master HAF X or cooler master Storm trooper (any good suggestion?)
Sound Card (need???) (Sound blaster??) Ps. Using 4.1 speaker
Monitor?? (Need to run 3d in 1080p 23’ to 27’) (Back light support)
Fan controller ??
Type A
CPU > i5 3XXX (SC1155)<(pls suggests) (Aftermarket cooler suggestion??) (want to oc around 4.5 ghz)
MOBO > Asus Saber tooth (not sure about it if got any good recommendation pls do so tq) (need a bit more pcie slot sound card + raid card??)
GPU > GTX 670 SLI or GTX 680 or GTX 690 or Sapphire 7950 crossfire or Sapphire 7970
In my country GTX 660 ti(reference=$333/aftermarket=$400)GTX 670 (reference=$383) (aftermarket=$500).GTX 690 (aftermarket $1266) .Sapphire 7970 ($433).Sapphire 7970 OC ($500).Gtx 680 (reference $ 599) (aftermarket $666 to $600)
Type B
CPU > i7 3XXX (SC1155)<(pls suggests) (Aftermarket cooler suggestion??) (want to oc around 4.5 ghz)
MOBO > Asus Saber tooth (not sure about it if got any good recommendation pls do so tq)(need a bit more pcie slot sound card + raid card??)
GPU > GTX 670 SLI or GTX 680() or Sapphire 7950 crossfire or Sapphire 7970
Type C
CPU > i7 3XXX (SC2011)<(pls suggests) (Aftermarket cooler suggestion??) (want to oc around 4.5 ghz)
Ps.I also open to any new type suggestion of build AMD or Intel.
Sorry for the long post &tq for hearing me out. Any help will do.
Current rig:
MOBO> MSI 890X-G65
HHD> WD 1TB Green
Planning Build:
Fan controller ??
Type A
Type B
Type C
