Help with build
joey666
20
i was thinking of buying a acer aspire predator g7200 case and just wanted to no if all this would fit ok in that case?and if everything else would fit together and is that psu ok with all that.its my first build so im a noob.
Intel Core i5-2500K
Sapphire Radeon HD 7850 OC
Antec EarthWatts EA-650D Green
4GB Corsair Vengeance blau PC3-12800U CL9
Seagate Barracuda 7200 500GB SATA 6GB's
ASUS P8Z68-V PRO GEN 3 LGA
thanks any help would be appreciated :D
-change the a i5 3570k
-get a hyper 212 evo cooler
-get a xfx 550w psu
-get 8gb of patriot intel extreme masters ram at 1600mhz
-change to a gigabyte z77x-d3h motherboard
-get at least a 7870. id recommend the xfx core edition 7870 for 209.99 after MIR at us.ncix
-get a better case. good one is a corsair 200R if you are looking for something cheap. or a fractal define R4 for 100 dollars
joey666
20
im not getting the case now but most of the stuff you said is over my budget (im already gone over it)and i already have the
ASUS P8Z68-V PRO GEN 3 is a 550 watt psu strong enough?i cant get the psu you mentioned i get all my stuff from http://lb.hardwareversand.de and they dont have it.im from ireland and anywhere else i look has exspensive delivery charges.
ok then do this
-change to a i5 3330, 3450, or 3470. whichever is cheaper
-switch to a matx h77 motherboard
-site doesnt work
-look for the cheapest cl9 2x4gb 1600mhz kit of ram you can find
-look for a fractal core 3000, corsair 200R, or antec 300. whichever is cheaper
lose overclocking but has just as much performance from stock
