First PC Build, Will It Work?
Hi,
This is my first time posting here and also my first time building a PC so I would like some of your opinions of the build I am trying to make and also will all the parts fit together right and will they be compatible with each other. If you have any better suggestions for any of the parts please say! :)
I need everything except an OS and a mouse.
Parts I need to buy are: (will they all fit together and are they all compatible with each other?+would you change anything to make it better/cheaper? Also my budget is literally £580 including monitor and keyboard)
CPU: Intel i3-2120 Sandybridge Core i3 Dual-Core Processor 3.30GHz
Link: http://www.amazon.co.uk/Intel-Sandybridge-Dual-Core-Processor-Warranty/dp/B004FA8NXM/ref=sr_1_1?s=computers&ie=UTF8&qid=1355346525&sr=1-1
Motherboard: Gigabyte XKT-1155 Z68AP-D3 Motherboard
Link: http://www.amazon.co.uk/Gigabyte-XKT-1155-Z68AP-D3-Motherboard-Rev/dp/B0054X4I4M/ref=pd_sim_computers_6
Case: CiT Vantage Type-R Gaming Case
Link: http://www.amazon.co.uk/CiT-Vantage-Type-R-Gaming-Reader/dp/B0064LFTR8/ref=sr_1_1?s=computers&ie=UTF8&qid=1355347662&sr=1-1
PSU: OCZ OCZ600MXSP-UK ModXStream Pro 600W ATX Power Supply
Link: http://www.amazon.co.uk/OCZ-OCZ600MXSP-UK-ModXStream-Power-Supply/dp/B001GLFD54/ref=sr_1_1?s=computers&ie=UTF8&qid=1355348342&sr=1-1
GPU: XFX ATI Radeon HD 6870
Link: http://www.amazon.co.uk/XFX-Radeon-HD-687A-ZHFC-Graphics-Memory/dp/B005C31F2M/ref=sr_1_5?s=computers&ie=UTF8&qid=1355346229&sr=1-5
RAM: Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit
Link: http://www.amazon.co.uk/Corsair-CMZ8GX3M2A1600C9-1600MHz-Vengeance-Memory/dp/B004CRSM4I/ref=pd_bxgy_computers_text_z
DVD Drive: Sony AD-7280S-0B 24x Internal SATA DVD Multi Writer Black Bare
Link: http://www.amazon.co.uk/gp/product/B0057FRTPW/ref=noref?ie=UTF8&psc=1&s=computers
HDD: Western Digital Scorpio Blue 500GB 5400 RPM SATA Mobile Internal Hard Drive OEM
Link: http://www.amazon.co.uk/Western-Digital-Internal-Playstation-Compatible/dp/B0037NYQ6Q/ref=sr_1_6?s=computers&ie=UTF8&qid=1355348614&sr=1-6
Case Fans: 2x Akasa AK-274CR-4RDS 12cm Red LED case fan
Link: http://www.amazon.co.uk/Akasa-AK-274CR-4RDS-12cm-Red-case/dp/B001D8J8JW/ref=sr_1_2?s=computers&ie=UTF8&qid=1355348708&sr=1-2
Keyboard: Logitech Compact UK QWERTY Keyboard Black
Link: http://compare.ebay.co.uk/like/190748876246?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&cbt=y
Monitor: SAMSUNG LS20B300NS 20" LED Monitor
Link: http://www.pcworld.co.uk/gbuk/samsung-ls20b300ns-20-led-monitor-12593024-pdt.html?srcid=369&xtor=AL-1&cmpid=aff~Reevoo~Desktop+PC+%26+Monitors~12593024&istCompanyId=9a35962d-802d-4e67-9721-0a3328ca1f02&istItemId=lqitlrtm&istBid=t
Total for all this is: £585
Thanks guys a lot, I really hope you can confirm all this is good and works! :D
6 answers Last reply
More about first build work
  1. Looks good, except for the power supply. Go with a one rail solution, like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371059
    Same price.
  2. 7870 instead,even the 7850 is better.
  3. Thanks for the quick response! The PSU you recommended look good too! But its a little bit more expensive in the UK, goes for about £70 and thats a little over my budget:( do you have any other cheaper recommendations? Thanks
  4. Quote:
    Thanks for the reply and ill check it out:) Its good to know what other choices I have:) Thanks!
  5. groundrat said:
    Hey thanks, the Corsair one looks pretty good and decent, think im gonna go with that one:) Thanks!
New Build Systems Product
