Approximate Purchase Date: Late December/ Early January
Budget Range: $1,200 - $1,500 or less with good reasons
System Usage from Most to Least Important: Gaming with plans to upgrade to 3 monitors and crossfire
Are you buying a monitor: I will upgrade those in a few months
Parts to Upgrade: All parts
Do you need to buy OS: Yes, Deciding on win 7 or 8
Preferred Website(s) for Parts: Newegg
Parts Preferences: NA
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: I will accept advice on some good options for eyefinity
Additional Comments: I want to see if you guys recommend any changes.. Ex different brand or size Also, if I should downgrade anything.
And Most Importantly, Why Are You Upgrading: I was way past due.
Potential Parts List:
Intel Core i5-3570K Ivy Bridge 3.4GHz
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1166683
ASRock Z77 Extreme6 LGA 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
SAPPHIRE 100351SR Radeon HD 7970 3GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202008
Rosewill CAPSTONE Series CAPSTONE-750
Intel 330 Series Maple Crest SSDSC2CT120A3K5 2.5" 120GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167121
Seagate Barracuda ST1000DM003 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
COOLER MASTER Hyper 212 EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
LITE-ON DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Rosewill THOR V2-White Edition
I appreciate any and all advice.
Thanks!
Overclocking: Maybe
LITE-ON DVD Burner
Thanks!
