Hey everybody,
I'm new to messing around with my computer and recently I have been getting tired of playing on all low settings with only 20fps while playing League of Legends so I went out and bought a new Nvidia gt 610 graphics card for my Hp Slimline s5510y. Crappy computer for gaming I know. I linked the specs of the computer and the graphics card to the name of them so you can see what I'm working with. I'm not concerned with the fact that the graphics card recommends a higher wattage than my pc has (300-350w to my pc's 220w).
So, to get to the point.... the graphics card isn't showing up in my device manager and when I uninstall the integrated graphics card that I have, the display adapter option goes away. I have changed in my BIOS from the PCI slot to the PCI-Express x16 slot where the card is seated. I have removed and reseated it several times, and the checked that the fan is spinning. It seems like it is plugged in just fine. and when I try to install the driver it tells me that it can't find the proper hardware. I have tried installing using both the cd it came with and finding the proper driver installer from nvidia's website. Another problem I'm having is that when I plug my monitor into the VGA port, it wont display anything, but I figure that may be because it isn't even installed yet.
So please if anyone can help me remedy this problem I would greatly appreciate it!
