Closed Solved
Powercolor Radeon HD 6850 running hot
Is it normal for my Radeon 6850 to idle at 43 degrees? It seems a bit hot for an idle temperature. Load temperature is 62 degrees (running crysis 2 maxed out).
16 answers Last reply Best Answer
More about powercolor radeon 6850 running
  1. Are you running multiple desktops? That can bump up your idle core clock and, as a result, your idle temperature. Check your idle clock with MSI Afterburner.
    My dual-fan Sapphire 6950 idles at ~43C with two monitors and ~35C with one with ambient temps around 18-20C.
    43 is a little high, but it's nothing terrible. It could be explained by bad case airflow. Could that be the issue?
  2. That's normal for my 6850s. It's within tolerance. My idle is 39*, I have a well ventilated case. How's your case fans?
    Airflow is good. I have two 120mm fans for intake and two 80mm for outtake also my power supply's 140mm as well. one of my 120mm fans is blowing directly on the graphics card withle the other is blowing on the CPU heatsink
    I replied to kajabla. Check out what i said about my case airflow
  5. Just checked my OC'ed 6850. It's sitting pretty at 39c on a single 1920 x 1080 monitor.
    My case is the Antec Gaming One and I have 4 Rosewill 120mm White LED 74.48CFM fans installed. Intake: Front & Side Panel Exhaust: Rear & Top
    http://i1308.photobucket.com/albums/s605/dscudella/39c_zpsc22160e4.jpg
    Must be the cooling solution of my card. I also run a single 1920x1080 VGA monitor.
  7. Ya, it seems the 6850 is normally around your level. Sounds like your problem isn't a problem.
    Your PSU shouldn't have anything to do with your case airflow. It should be drawing in from the bottom of your case and blowing out the back.
  8. what brand of 6850 do you have? I have the asus dcuII or whatever it is. Two of them in CF. Both cards are teh same.
    Well in my case it isn't at the bottom.
    PowerColor
  11. Best answer
    Oops. Well, everyone's advice still holds: you're fine.
  12. Your temps are normal and there is nothing to be concerned about as your temps.
    Ok then :D oh and btw i saw your PC spec and i also got an overkill power supply :D , i have the 6850 which i thought runs a little hot and an intel core i5-3570 (non K) and i put in a Corsair AX850
  14. Best answer selected by lazar_99.
Graphics Cards Temperature PowerColor Radeon Graphics Product
