Hey there...
So I'm looking for a computer --- MAINLY TO PLAY WORLD OF TANKS on it's best settings. But I'd like it to be good enough to BF3 as well. However, WoT is the main game.... its pretty difficult to play on my laptop... haha.
At any rate, I was at a big box store discussing this with an associate and he suggested the HP Envy h8-1414. He says this will play the game on it's best settings. He then said if I wanted to play BF3 on it's best settings, I'd just need to upgrade the graphics card to an AMD 7770.
What say you? I'm including the specs here. What I would like to ask is this: This computer is $699. I know I'm not investing a ton but the criteria is set. Can I build a BETTER computer for $700? Can you? Taking all suggestions...
Motherboard
M3970AM-HP (Angelica2)
Processor
AMD FX-6120
Memory
10 GB
Video graphics
AMD Radeon HD 7450
Sound/Audio
Integrated IDT 92HD89E Audio
Hard drive
1 TB
CD/DVD disc drive
SuperMulti DVD Burner drive
Power Supply
Internal 300W (100V-240V)
Form factor: Internal ATX
Total wattage: 300W
Keyboard, mouse and input devices
USB keyboard with volume control
HP USB optical mouse
Motherboard
Processor
AMD FX-6120
Memory
10 GB
Video graphics
AMD Radeon HD 7450
Sound/Audio
Hard drive
1 TB
CD/DVD disc drive
Power Supply
Total wattage: 300W
