Need ideas for a entry level gaming build!
Approximate Purchase Date: e.g.: I will be purchasing the parts by Christmas
Budget Range: $450-$550
System Usage from Most to Least Important: Gaming & Surfing the web, Video editing and rendering
Are you buying a monitor: No
Parts to Upgrade: N/A
Do you need to buy OS: No
Preferred Website(s) for Parts: msy.com.au or pccasegear.com
Parts Preferences: I would like this PC to last me a year or two
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 1280x1024 I'm fine with this outdated resolution ^^
Additional Comments: I would like this to run quietly. I would also like the PC to be able to run and record most games on mid/high settings on my resolution with no problems.
And Most Importantly, Why Are You Upgrading: Outdated PC can't handle gaming anymore, its time for an upgrade!
3 answers Last reply
More about need ideas entry level gaming build
    Overclocking: Maybe
    You may have read this article already, but just in case you hadn't I wanted to link you a build that Tom's put together for a gaming PC at $500:
    http://www.tomshardware.com/reviews/budget-gaming-do-it-yourself-computer,3364.html
    Here's another similar article from AnandTech:
    http://www.anandtech.com/show/6182/fall-budget-system-buyers-guide/3
    I'll leave the rest to the experts!
    The problem with that Anandtech build is that it uses a really low end video card and a PSU that leaves no room to upgrade. The Tom's build is better but they do cut a lot of corners on CPU and RAM, but then on a $500 budget you have to make sacrifices somewhere.
    I definitely would agree with you there. Tom's ability to work a Radeon 7850 into its build is a huge advantage.
New Build Gaming Resolution Systems
