Hoping people can recommend some pre-built or even DIY systems. The budget is 0<b<=1000 (shipped). I built a few configs on cyberpower and ibuypower, but with shipping they were over $1000 and they won't arrive until after Xmas.
My current system is mentioned below, along with the problems it's experiencing.
4 year old system:
Q9450 Processor
ASUS P5K SE Motherboard
500 HB HD
PNY 9800 GTX Video Card
8 G RAM
Rosewill 600W Power
I'm a low-mid end gamer PC person, who also does some video editing and hobby 3D rendering - book covers, some animation. This system runs the games I play (NBA 2K13, SC2, Empire Earth II) and the applications I run (various video editors, sound editors, poser pro.)
Recently the video card failed. The system locked while playing a game, then on reboot there were white dots all over the screen. I replaced the card with a Radeon HD 6750 from Best Buy, but because it was overpriced there I purchased a Sapphire HD 7770 (for less online.) The system worked fine for a day with that card, but on day two the system kept rebooting before it began loading windows. Finally it booted, but then froze in the middle of SC 2 play.
I opened the case, found some dust near the bottom, cleaned it, re-seeded the video card, re-sealed the system. It hasn't crashed since then. Disk checks show the HD is OK. AIDA64 and memtest86 found no problems - no mem problems and the system remained stable and the temperatures within acceptable ranges for all the components. However even before the big crash (even when the 9800 GTX was in the system) sometimes it wouldn't boot - it would freeze on the windows screen.
I'm worried the system is close to failure. Not sure what is the problem since the tests show no problems. In 2008 the system was a mid range $1250 system from an eBay builder.
This system for $599 is a decent upgrade. http://www.newegg.com/Product/Product.aspx?Item=N82E16883229361 I'm not happy with the GPU, although it's an upgrade over what I had. I'm not 100% sure that the 7770 isn't bad, so I'd rather return it and purchase a complete system with vid card.
4 year old system:
Q9450 Processor
500 HB HD
8 G RAM
Rosewill 600W Power
