Hi everyone. I'm looking to build my second PC soon, but I realise in the grand scheme of things there's some basic info which I realise I don't know, and I want to make sure I'm getting the most out of the new PC while at the same time, making sure I don't go overboard and get parts that I won't be getting the full use out of, or parts that actually turn out to be sub par. So while I look at some of the guides here, I'd like to fire a few questions at you all.
First up, I'll probably only be getting a single Graphics card so I won't have need for multiple PCI-Express slots. With that in mind, would it be better/cheaper to get a micro-ITX motherboard with a smaller case, or would something like that have airflow/cooling issues with everything being closer together?
Speaking of motherboards, it's most likely going to be an i5 processor I get, but I don't know the difference between the different chipsets on the motherboard. I can only assume that Z77 are the current best... and obviously I should look at what the motherboard actually has in regards to Sata, Ram and PCI-E slots... but what is the actual difference between the chipsets?
Speaking of Sata. I've heard that HDDs don't get the full benefit of Sata 6Gb because of the limitations of their design. Is this true? And are the ones that are advertised just saying that they are compatible with the 6Gb slots?
Thanks in advance. I current computer has suffered from stability issues from the fact that I went in with a large amount of ignorance. I want to make sure I do it better this time.
