I just upgraded to a 7870 GPU and a 650W PSU.
The card that I got came with a program similar to MSU Afterburner that allows you to overclock the card, and it also monitors the card temperature and power status. Since I got the new components, I have noticed it seems really warm underneath my desk, and my computer has been freezing while gaming. Its not just the game either, I cannot alt+tab and get back to windows, the whole comp freezes and I have to turn the system off.
I opened the overclocking window to check the card temperature, and its under 40 degrees Celsius. I opened my case and the card is ice cold, however it seems like its the PSU that is overheating, this is where all the heat is coming from. The overclocking program dosent monitor the temp of the PSU, but the icon turns red. Is the PSU overheating and this is causing the crash? Do I need to open the case and put a house fan up next to it?
I asked the community here for advice on a GPU and PSU before I upgraded, and was told a 550w PSU would be enough for what I play (pretty much just WOW). I had some extra cash and got a 650w just to be safe. Why would it be overheating?
The only thing I can think of is my previous PSU had the fan on the rear blowing out the back of the tower and then new one has the fan on the bottom..... could this be the problem?
I never had a problem running games before I upgraded from a 5500 series GPU and a 350w PSU.
