SLI Problem (560 ti w/ 448 EVGA)
Hello forum,
I am having issues with my SLI set up. I have this card ( http://www.newegg.com/Product/Product.aspx?Item=N82E16814130738 ) and am seeing issues exactly the same as this guy ( http://www.tomshardware.com/forum/367391-33-560ti-flickering ).
In any game I play the screen flickers constantly.
He never seems to have fixed his issue. I have tried, using each card in both slots individually, using both cards together in both slots, reinstalling drivers completely (using the guide linked to in the previously mentioned thread), and using a different SLI bridge.
Here are my system specs:
GIGABYTE GA-Z68A-D3H-B3 Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128502
2x EVGA GeForce GTX 560 Ti (Fermi) 448 Cores FTW
Rosewill LIGHTNING 1000W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182239
Intel Core i7-2700K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115095
CORSAIR Vengeance 8GB Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Corsair Force Series 3 60GB SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233223
2x Western Digital 320GB Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098
Any ideas on how to fix this issue?
Thank you.
11 answers Last reply
More about problem evga
  1. Which SLI mode are you using?
    • Auto
    • Split Frame Rendering (SFR)
    • Alternate Frame Rendering (AFR)
    • Alternate Frame Rendering 2 (AFR2)
    I've seen Split Frame Rendering (SFR) mode do that at one time when I was running an SLI setup.
    Try AFR or AFR2 to see if it makes any difference.
  2. When the cards are installed in the PCIEX16 and PCIEX8 slots what does GPU-Z report for the Bus Interface when the graphics cards are put under load?
    • Auto
    I am using the default nvidia control panel thingy... How would I change this?
    I have used this but only when they are not under load. What would you recommend for testing in in that way? Just run any game for a few mins with GPU-Z running?
    1. From the NVIDIA Control Panel tool bar, switch to Advanced View and then click Manage 3D Settings from the Select a Task pane.
    2. Click the Global Settings tab, and then click the Global presets list arrow and select Base profile.
    3. Under the Settings Feature column, locate SLI performance mode, click its setting to activate the list box, then click NVIDIA Recommended or AFR 1 or AFR 2 or SFR.
    4. Click Apply.
    On the right-hand side of the Bus Interface display field there is a ? symbol, that you can click on, that will pop up a Render Test window. Click on the Start Render Test command button to put the selected graphics card under load and watch to see if the Bus Interface display field changes.
    Do the above for both graphics cards (i.e. select each graphics card in the drop down list box at the bottom left corner of GPU-Z).
    4. Click Apply.
    Ok when trying each setting the only one that worked was single GPU and Im pretty sure that means its not using the SLI...
    Yes I do see the second card change from
    "PCI-E 2.0 x16 @x8 2.0"
    to
    PCI-E 1.1 x16 @x8 1.1"
    after a few seconds
  9. What does that mean?
  10. When the computer and graphics card is idling the bus interface field should be displaying PCI-E 1.1 x16 @ x8 1.1 (i.e. it may take several seconds before it drops to this mode).
    Once the graphics card has been placed under any graphics processing load (i.e. sometimes it only takes an animated smiley being displayed) it should switch to PCI-E 2.0 x16 @ x8 2.0. Once the animated smiley is scrolled so that it's not visible anymore the bus interface should drop back down to PCI-E 1.1 x16 @ x8 1.1. This is completely normal behavior.
    You're correct. Only one graphics card is being used.
    At this point I don't have any suggestions to get the second card working because I don't have an SLI rig to work with anymore.
  11. Ok well thanks for the ideas... Any recomendations on where to look for more help?
Graphics Cards SLI Graphics Product
