Will a Sapphire Vapor-X HD 7770 work with my mobo?
Related ressources:
- ForumWill the SAPPHIRE HD 7770 VAPOR-X work in my mac pro 3,1
- ForumSAPPHIRE HD 7770 VAPOR-X
- ForumCrossfire Sapphire HD7770 Vapor-X
- ForumOC 7770 vapor-x
- ForumComputer freezes when playing with Sapphire HD 7770 Vapor-X
- ForumHD 7770 Vapor-x Ghz Edition won't boot
- ForumSapphire HD 7770 Vapor-X better than EVGA GeForce 560?
- ForumSAPPHIRE TOXIC HD 6850 or SAPPHIRE VAPOR-X HD 7770 GHz EDITION OC
- ForumPalit GTX 650 vs Sapphire 7770 Vapor X vs Palit 6870?
- ForumSapphire HD 7770 OC vs HD 7770 Vapor-X OC. What is the temp. diff?
- ForumGigabyte GA-870A-USB3L + SAPPHIRE VAPOR-X HD 7770 GHz Edition?
- ForumUpgrade options for sapphire hd7770
- ForumSapphire Vapor-X 7770 problem
- ForumSAPPHIRE > HD7770 or HD 6850 ??
- ForumSapphire hd 7770 vaporx vs evga gtx 650
- ForumProblems with Sapphire HD 5770 Vapor-X !
- ForumSapphire 7950 Vapor-X Overclock
- ForumSapphire Toxic HD 4890 Vapor-X (factory OC to 960 MHz)
- ForumHD 7870
- ForumWill the GTX 650 ti SSC (2GB) run Flight Simulator X nicely?
- More resources
. Can i plug this GPU into my Mobo without frying it? I know it uses a direct power supply, but still i am very scared of doing something wrong because once i bought a high end GPU(back in the days) and i plugged it into the mobo and it worked fine for a year or so but then it died and the guy that was repairing my pc said that the mobo pci was something like 1.5(not sure) and that card needs 3.0 or something like that... So i lost a lot of money...
