Solved
Will all of my components work together?
CPU: Intel Core i7-3770 3.4GHz Quad-Core Processor
Motherboard: ASRock Z75 Pro3 ATX LGA1155 Motherboard
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 660 Ti 2GB Video Card
Case: Thermaltake VL800P1W2N (Black/Red) ATX Mid Tower Case
Power Supply: CoolMax 600W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply
Optical Drive: Lite-On IHAS324-98 DVD/CD Writer
Total: $822.91
I want to make sure my parts will fit in the case properly and so that everything runs smoothly. Thank you guys so much, you have been great help so far! :D
3 answers Last reply Best Answer
More about will components work together
  1. Best answer
    Core i7-3770 on Z75 motherboard: Check
    DDR3-1600 on Z75 motherboard: Check
    GTX 660 Ti 2GB Video Card on Z75 motherboard: Check
    ATX Mid Tower Case for ATX LGA1155 motherboard: Should fit OK
    600W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply is probably overkill and will give you plenty of headroom for later upgrades.
    None of the parts are extended length or anything unusual, so...
    Looks fine to me.
  2. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  3. Best answer selected by greathelp.
New Build Systems
