Hello guys I am seriously seeking some help as everything I have done has failed!!
I have a Alienware X51 i7 PC with a Nvidia GTX555 Graphics card.
I am pretty much a novice when it comes to anything inside a PC but have caused myself rather a terrible problem
I was having issues with my frame rate on certain games and decided to reinstall my graphics card drivers etc etc
I read online that the best way to do this was to install driver sweeper and remove all traces of the hardware and do a complete clean install.
I installed the program and deleted what I was asked too according to the post but the minute I did "NO DISPLAY"
I researched for a few hours and after resseting the COSM I was able to recieve a picture without the Nvidia card connect.
But ever since then when attaching the Nvdia card the PC will shut itself down and reboot itself after couple of seconds with NO PICTURE!?
I have tried connecting it in safe mode,Normal mode but everytime I connect the card into the PCI the PC dies,Reboots but with no signal.I have also tried restoring the drivers on the driver sweeper program both in safe mode and normal mode but no luck,Also I have tried a system restore to a few days before the incident which didnt help
I am running the PC through a HDMI cable to the pc and do not have a mini HDMI or DVI cable to connect direct to the graphics card
(Not sure if this would help anyway)
I am unable to download the drivers from Nvidia direct as I need the graphics card connected in order to download and run the installer which obviously results in no picture so that is also a no go.
I really do not no what to do guys any help or advice would be so helpfull!!
Kind regards
Kind regards
