Solved
First Build - Need Parts Advice [2k budget]
Hi all,
I've been watching lots of videos on the actual process of the build and I'm starting to feel pretty confident about starting my first build.
What I'm not so confident with is picking out compatible parts for what I'm looking to use my computer for.
I will primarily be using this build for gaming and video editing.
I would really like a 3 monitor setup to space my video editing work load across and also to game on.
I have a really flexible budget of 2k and I'm willing to spend more if I need to.
This budget doesn't include the monitors, so I would appreciate any suggestion on those as well.
I really appreciate any help I can get as I really want to get started on my first build and feel confident that the parts I'm putting in are good and right for me.
Thanks so much!
7 answers Last reply Best Answer
More about first build parts advice budget
  1. Best answer
    If gaming across 3 monitors, I would shift a lot of the budget towards the graphics card. The HD 7970 Ghz Edition would be ideal, it's a powerful single card and would keep you away from hot/noisy dual card setups.
    i7-3770k
    2x8GB Corsair Vengeance LP 1600Mhz 1.5v C9
    ASRock Z77 Extreme4
    Sapphire HD 7970 3GB Ghz Edition
    Samsung 840 Pro Series 256GB
    Samsung Spinpoint F3 1TB
    Seasonic G Series 550W
    ATX case of choice
    Total should be around $1500, I don't really see any reason to spend any more than that to be honest. Maybe a decent CPU cooler or more storage but that's about it. If you go for more storage, I'd just get multiple F3 drives and RAID them up or something. A RAID 1 setup might be cool.
    EDIT: These would be really good for monitors
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824005240
    Cheap, nice IPS panel so good colours and viewing angles. Also fully adjustable and 5ms response time. Good all rounder.
  2. Thank you so much for the input, very helpful and exactly what I was looking for!
  3. Best answer selected by syphn.
  4. This might be a stupid question, but the back of the graphics card appears to only have 2 inputs to plug in monitors. I see it also has an HDMI, but it doesn't look the monitors do.
  5. http://www.newegg.com/Product/Product.aspx?Item=N82E16812576006
    There's your easiest option.
    I think I remember someone saying you could turn a dual link DVI connection into two independent DVI connections as well but I'm not sure if that's possible.
  6. Thanks for that, do you think this monitor would be good for gaming? I like that it has virtually no bevels: http://www.newegg.com/Product/Product.aspx?Item=N82E16824260109
  7. Yeah it should be OK. A lower response time would be ideal but it shouldn't make a huge difference.
Homebuilt Video Editing Build Systems Product
