Running WoW: MoP badly.
Last response: in Systems
December 18, 2012 7:36:57 PM
Radeon HD 6950 1GB
8 GB G.Skill RAM
AMD 4100 (OC'd to 4.3GHz)
I don't get why I run WoW so badly, usually around 30 FPS on GOOD settings, don't even get me started on ultra. Did something significant change with MoP? I used to run WoW almost at constant 60 before MoP. Anyone have similar experiences?
More about : running wow mop badly
December 19, 2012 8:18:48 PM
rfas said:
Radeon HD 6950 1GB
8 GB G.Skill RAM
I had a similar issue running a Radeon 5770, i3 and 16 GB ram. In raids fps was dropping to 3. I was able to remedy the problem by updating drivers to 12.10. Then I set all settings to Low and resolution to less than the 1900x1080. I incrementally increased the settings and am back at 60pfs (vertical synced). Keep in mind that shadows and projected textures tax your card pretty hard.
m
l
December 19, 2012 8:19:30 PM
rfas said:
Radeon HD 6950 1GB
8 GB G.Skill RAM
Oh! make sure that the background down loader isn't running. To check, launch the launcher and make sure that the DL is complete. This is majorly taxing on FPS.
m
l
