What is a system discdisc boot failure insert system disc and press enter
what is a system boot disc?
1 answer Last reply
More about what system discdisc boot failure insert system disc press enter
  1. It is the drive from which your system boots. An error message regarding this often means that your computers BIOS cannot find a bootable disc. Check the connectors on your hard drives---a cord might not be properly seated.
    If everything appears to be fine cord-wise, try plugging in and unplugging your USB peripherals each time you boot. I know in the past one of my motherboards refused to recognize that I had a hard drive unless I had a specific flash drive plugged in as well.
New Build Boot Failure Boot Systems
