Archived from groups: rec.photo.digital.slr-systems (More info?)
I have a Nikon D100, which has now become the backup for my D2X. So
the D100 batteries (which are not the same size as the D2X's) won't
get used much.
Is it better to just let the D100 batteries run down, and then charge
them up just before a trip on which I'm taking the D100 (maybe
4x/year), or is it better to charge them every month or so to keep
them from running down?
I've read that L-ion batteries have a limited number of charge cycles,
but that they won't be damaged if left to run down (as some earlier
NiCads would).
> get used much.
> NiCads would).
> Any advice?
If the L-ion batteries last only one quarter of the 1000 or so charge /
discharge cycles that they are supposed to, and if you do charge them
once a month, then how long might they last? I don't think you have
any worries either way.
Li-ion batteries are different chemistry than other rechargeables. For
notebook Li-ion the better rule for longevity seems to be to charge [or
discharge] to 40% and keep in a cold place [refrigerate].
I assume the same rule would apply to my Canon Li-ion battery.
Whatever the best recipe is, it's not very practical. I just charge it
up and use the camera. When the 'batt low' has been on for a while or
the camera shuts down, I recharge the battery.
I have no means to determine if the battert is at 40% capacity in any case.
My advice: Shoot a lot of images and keep that battery busy.
It's cheap compared to film if you need to buy another one.
Alan Browne wrote:
For
[or
it
or
case.
It's cheap compared to computer batteries when you have to buy one. I
can't find a sensible generic for my Toshiba, so I'm looking at about
$115 minimum. It's not much of a battery, either, but I think there are
so damned many different laptop battery configurations, generics are
not likely to happen. To keep it on topic, I download my CFs to the
laptop when they're full.
Charlie Self wrote:
> Alan Browne wrote:
> For
> [or
> it
> or
> case.
>> get used much.
>> NiCads would).
>> Any advice?
Tim Smith <tssmith@sonic.net> wrote in
news:l194911eq8sl5d2h29ln268kbrggjgg637@4ax.com:
> Uh, good point.
Here's another good point:
I bought 4 Sterlingtek 1800mAh batteries for my 10D, they cost $12 each.
They work well and if they are good for a couple of years then I am happy.
I don't mind replacing batteries now and then when they are that cheap. My
point is that I read these posts about batteries, but don't see what the
big deal is!
Batteries are consumables, rechargeables are no exception.
Mark Heyes (New Zealand)
See my pics at www.gigatech.co.nz (last updated 3-May-05)
"There are 10 types of people, those that
understand binary and those that don't"
>>Uh, good point.
> big deal is!
These days, everything that uses power to operate should be considered a
consumable. I have a feeling that Lithium Ion batteries might outlast
the practical life of most DSLRs. 1,000 charge cycles X 500 - 2000
shots per charge is several shutter and mirror mechanism replacements.
Alan Browne wrote:
>> For notebook Li-ion the better rule for longevity seems to be to
>> charge [or discharge] to 40% and keep in a cold place [refrigerate].
> Cheers,
> Alan
Agree...Picked up a handful of extra batteries so I never run out and I
just don't worry about it...Had my first Li-ion die on me this past week
(for the Canon 300D) Got almost 18 months out of it in constant use...
Frederick <nomailplease@nomail.com> wrote in
news:1116890785.169828@ftpsrv1:
> a consumable. I have a feeling that Lithium Ion batteries might
> outlast the practical life of most DSLRs. 1,000 charge cycles X 500 -
> 2000 shots per charge is several shutter and mirror mechanism
> replacements.
I doubt that most people would get anywhere near 1000 charge cycles.
Lithium Ion batteries have a limited life in terms of year since
manufacture - the performance will degrade over the years and after 3 - 5
years most people will be dissatisfied with the amount of charged stored.
Unfortunately this probably means $12 down the tubes for a replacement, how
could life be so unfair!
BTW
If anyone has a Lithium Ion battery that is over 6 years old and giving
just as long a life on each charge as when brand new, you are probably
delusional. My experience with laptops, cell phones and digital cameras
would suggest that you would have less then half the original runtime after
6 years.
>>replacements.
> BTW
> 6 years.
Agreed,
Laptop batteries seem to have about half the original _claimed_ runtime
even when they are brand new. Somewhere in the fine print the specs
probably say x hours per charge - so long as you don't use it. I have
had better luck with cellphones and cameras.
Frederick wrote:
> Agreed,
I've had nominal (spec like) performance from my Li-ion battery.
Frankly it was an area of some trepidation as I launched into digital
SLR's but has proven to be something I barely worry about.
For a trip this summer to Labrador I'll be getting an inverter for the
truck to recharge it and the laptop. I'll possibly buy another battery
but I'm not convinced it's a neccessity.
"Alan Browne" <alan.browne@freelunchVideotron.ca> wrote in message
news6vdnb$sve$1@inews.gazeta.pl...
> Frederick wrote:
>> Agreed,
>> probably say x hours per charge - so long as you don't use it. I have had
> I've had nominal (spec like) performance from my Li-ion battery. Frankly
> it was an area of some trepidation as I launched into digital SLR's but
> Cheers,
> Alan.
Remember, the specs always say "up to." Up to 4 hours can be two minutes.
<BG> Up to 100 shots can be 3.
Cute, and not altogether wrong, but I've shot on the order of 400-500
images (RAW+JPG) per battery charge. I don't use auto-focus or the
built in flash, so that all certainly helps.
The first two charges of the battery gave okay performance, after that
it seemed as if the performance improved. I wasn't really sure, or
writing it down, so I just put it to 'impression'. Then I saw a post
where the poster said that Li-ion take a few charge/discharge cycles to
'condition' themselves. Whatever it is, Li-ion are great.
