Tier 4 - Not Recommend for stressful situations. May not be able to put out full rated power above room temperature, and may slightly fail to meet ATX specs. http://www.eggxpert.com/forums/permalink/323050/323050/ShowThread.aspx#323050
cool thanks for all the help just checked aero cools site they say the psu has 30A per rail and supports up to 648W of power. hope its good enough checking out the psu you recommended now
It should be good enough i did some more research i think you will be o.k.
Thanks for all the help..... and then i need to decide between 3rd generation i7 3770 or an i5 for gaming wich one is beter heard games experience some problems with hyper threading
